Stripped Thread Repair Valve Cover Studs
jetmechmarty
Project collector
XS650.com Supporter
Coldwater, Mississippi
My engine swap is taking an eternity, so far. A while back, I made one of these repairs after seeing it on the YouTube Channel FIX MY HOG. This time, I’m documenting it for your pleasure.
I have two stripped holes.
Release agent.
Five minutes, then back it off.
New threads.
And, I’m done!
I hadn't seen this one, how do you think it compares to helicoil? I see the disclaimer on the packaging.
john
I do not think this compares to helicoil. I used it a few years ago to make threads on an XS gas cap. It has been holding against that spring pressure all this time and I didn’t repair threads, I made new ones. On this valve cover, I think it’s great. I saved me time and money. If it fails, I can still install a helicoil, or do this again. On FIX MY HOG, they used it to install engine covers where the case stripped. I believe it’s perfectly appropriate for that.
Loctite's Form-A-Thread product data sheet specifies 45 inch pounds as maximum torque on 8 mm. fasteners (for the math challenged, that's just shy of 4 foot pounds).The 1,538 inch pound limit specified on the package applies to 14 mm. fasteners. On small fasteners, use only in light duty applications--like valve cover studs. Nice work, Marty.
Since these covers use 3 bolts the other 2 can take up most of the duty of that stripped one via leverage. A new silicone o-ring and CAREFUL snugging of the other two I'd guess you wouldn't even need to replace the stripped one. Good call Marty!
Pretty sure I've tip toed past a stripping out valve cover stud a time or two.
I've used JB Weld to do the same thing. The most important thing is surface prep. Everything as to be clean. Any thing on the surfaces will cause a failure.
I actually learned this trick as a kid flying model airplanes. Ripped out screw holes were repaired with Devcon 5 Minute Epoxy. I used Vaseline on the screws as a release agent.
The LOCTITE stuff leaves nice neat threads. In this case, I didn’t add enough time to account for the cold. Just the same, I believe it will hold fine.
Hey, folks. I am dealing with the same problem. Bottom stud on the right exhaust valve cover. I've looked through the threads and seen the various fixes: Gary's "meatball mechanic" homemade reducer stud, JB Weld, or high-temp/slow-set epoxy, Marty's form-a-thread, and Heli Coil. I don't think I am going to do Gary's thing, although it seems very good. So any recommendations on which way to jump? Has anyone tried a Time Sert style thing here - is there enough meat in the casting for that? Thanks very much! Justin
