So after spending the day installing my new hydraulic clutch conversion kit (which works great btw ), I decided to go ahead and change my oil since I am getting ready for a short roadtrip next week.
I have the Heiden oil filter/cooler mod and have never had any troubles with it. I successfully removed one housing bolt....however, the right side bolt won't budge! These are hexhead bolts and easily rounded out.
If the stuck bolt had been on the left side I think I could've gotten one side out and unscrew the other with the actual aluminum piece. But no, it couldn't possibly be that easy for me
I had previously bought one of those screw/bolt extractor kits for these types of situations (had same issue on brushes screws), but to my surprise and no avail the bolt will still not budge! I'm recharging my drill right now to see if a power boost would help. The head is too far in to cut a notch with a dremel, and I've done my share of trying to bang in a screwdriver slot. Can't even take off the side of the engine cover because the cooler block one of the bolts.
If I get desperate enough I may just saw into the metal down to the bolt head to cut the notch and turn the bolt out.....but that would ruin a beautiful oil cooler and I'm not feeling charitable since I just ordered other non-related parts.
Any suggestions? Keep trying with the bolt extractor?
P.S. No access to welding etc stuff so can't try those solutions
