furrygreg
The bike is a 1978 XS650SE. Had 8500 original miles prior to rebuild. Went through the entire engine last year while doing the build. Cylinders only required honing, no oversize. Crank & cam are OEM. All bearings & bushings measured well within limits. Besides replacing normal wear & tear parts such as cam chain guides, the only internal engine mod was to upgrade to Mike's new 5th gear with the extra tooth. We installed a Boyer Brandsden ignition system and a Mike's PMA charging system. The carbs are Mikuni VM34's with cone filters, and the exhaust is a MAC two into one megaphone. The bike runs very strong and never gives me a problem. I can kick it from cold if I want even though i am running a Boyer Brandsden electronic ignition and not the PAMCO system. The charging system puts out 14 to 14.5 volts depending on if I am running at idle or 2000 RPM's or more. The timing is set up per Boyer instructions to 12 degrees before TDC. The carbs currently have a 159 series P5 needle jet, 6F9 needle, 210 series 20 pilot jet, & a 4/042 series 180 main jet. The needle clip is set to the center position. The elevation at Tucson Arizona is about 2500 FT. The fuel mixture screws are set at 3/4 turn out from bottom each. Both were adjusted using the dead cylinder method. The idle screws are set so that the engine idles at 1200 RPM's with the engine warm. My son and i have put over 2500 miles on the bike since the build was completed last January. This was our first bike project together, and because of all the info and parts that are available out there, the bike turned out very well. We get a lot of people walking up the bike wanting to know about it. The only problem I have is a nagging stuttering problem when running around 80 MPH at 4500 RPM. If I go above or below those parameters, the bike is smooth as silk. Sometimes I get a little stuttering when accelerating from a stop if I don't "roll" the throttle. Reading the tuning manual, I should probably go down one size main jet. Should i adjust the needle clip or the pilot jet as well? I have topped the bike out to about 110 MPH on a long open road before it ran out of steam. I am very open to experienced advice. If I can get this last problem solved, i will be one happy mid-life crisis dad. Thanks for the help.
