member3480
RICH
OK I have been playing with these switches and they work good but you will go nuts on the colors of the wires nothing is what you think. So for you guys buying these I am going to make it easy for you and break down the wires,
I also sells these if you need to buy. These are close to stock but half the price.
LEFT SWITCH which is HORN - High/LOW - TURN SIGNALS
HORN.......... is 2 wires Lite Green and Dark Green
TAKE YOUR PICK BECAUSE its 12 VOLTS in 12 VOLTS OUT
HIGH/LOW...... is 3 wires BLUE HIGH/ WHITE LOW/ BROWN 12 volts
TURN SIGNAL...... is 3 wires ORANGE LEFT TURN / LITE BLUE RIGHT TURN
and GRAY 12 volts ( PUT YOUR FLASER on GRAY WIRE )
RIGHT SWITCH which is STARTER BUTTON - LIGHTS ON - KILL
STARTER is 1 wire to ground YELLOW/RED ( to soliniod ground )
LIGHTS ON is a over kill and can be used as a H/L also 4 wires
BROWN RUNNING LIGHT to TAIL LIGHT
BROWN/WHITE LOW BEAM
BLUE/WHITE HIGH BEAM
BLACK 12 volts YES I SAID BLACK!!!!!!! 12 VOLTS
KILL is 3 wires GRAY 12 volts IN!!! ORANGE 12 volts out to coil/ignition BLUE also 12volts out to what ever you also want to kill.
I USE ORANGE to COIL and BLUE to IGNITION
AND these are 6 pin small so easy to adapt .
OK I hope I helped because these work well but a little hard to read the wires. Pictures below of switches.
