I have a 83 special with a TCI. I have tried to repair the TCI by replacing the transistor and it still doesnt work. I want to get this running the cheapest and easiest way possible. I have a points cam bolt and found a points plate with advance. I can get them for around 30 dallors. can I use the TCI coil with a ballast resistor for these points? Is there a cheap replacement for the condesnor? Also will a xs400 points plate and advance work with a xs650? is there anything else that I might be missing? Thanks everyone
