barelycompetent
81 XS650 Special
Hi all, its me again lol. I just recently had my 1981 charging system completely gone thru because my headlight was not coming on when the bike was started. Turns out I had a bad rotor, got that all replaced and fixed up and the bike was charging and running like it was supposed to, headlight working just fine. Well I cafe'ed it over the winter, and I relocated some of the components like the TCI box, the RLD, and the safety relay, all mounted on a metal plate I welded on to the back of the frame. I did not chop, or cut any of the wiring for these components, just relocated them. I just wired in a new fuse box as well, switched from the glass fuses to blade fuses. When I start the bike up it was instantly blowing my headlight fuse. Took me about 3 fuses before I started checking all of my connections, Im slow like that. What I found was that where I had mounted the safety relay to the metal plate, the contacts on the bottom of the relay were grounding out to that plate and blowing the fuse. Once I straightened that out, the headlight came on when the bike was running. Took it for a spin and ran out of gas right around the corner from my house. No big deal, put in fresh gas, fired it up and now my headlight is out again. I checked the fuse, its good, so I went to the safety relay. Heres what I have checked so far, dont know what else I can do from here. I checked for 6 volts on the yellow wire, and I have that going to the relay. There are two red/white wires coming from the relay, I have 12 volts on one of them, and nothing on the other. When I take a jumper from the red/white to the blue black the light comes on. I have followed curlys charging guide, just to make sure that its not my charging system again, and that all checks good. My readings at the safety relay check good as far as I know, Im getting the proper voltage needed to trip the safety relay, but my headlight is still not coming on. Is there anything else I can do to check the relay, so that I can determine once and for all if that is the bad component? Am I checking it correctly? Can I bypass it if it is bad? Sorry for the long post, and I appreciate any replies. Its so frustrating, Im so close to having this bike done, it its not one thing its another.
