Maybe,maybe not. They may bolt together and if so can be made to work. Carb tuning can be a bit more frustrating though.
Pilot jets get air flow from ports in the carb bell to mix with the fuel then send it on it's way. Some years use a jet that mixes air from the top, others from the bottom.
Thought I had some pics showing these differences in the float bowls. Can't seem to find them. Ought to get my pics better organized.
I had a set of 76/77 carbs with earlier float bowls on them. They drove me crazy trying to tune them. The earlier carbs used one type of set up the later the other. Once I realized this and altered my procedures to match then things worked ok.
The earlier had the air mixing before the pilot get metered it so the jets need to be larger. In the mid 40's sizes. The later metered the fuel then mixed it. These used jets in the mid 20's range. When trying to use one jet in the other bowls things don't work.
You need to know which bowls those are and use the right jets.
Once I figured that out my bike did ok.
On those bowls you see a passage that runs across the top of the pilot jet. It comes down from the top turns to the right about 45* when it crosses the jet and goes down and turns down again. This bowl uses jets that mix air after metering the fuel. Fuel flows up from the float bowl through the jet and mixes wirth air in that passage then goes onto where it comes out ports by the throttle plate.
This set up was used on the 76 to 79 carb sets. They used jets in the mid 20's range.
The earlier float bowls had a hole drilled from where that passage turns down below the jet at an angle so it allowed air to flow down to fix with fuel before it passes through the jet. These jets needed to be larger to pass the mixture. Thus jets in the mid 40's range.
As I mentioned this won't be a real problem as long as you realize this and alter your tuning to match. The next owner may find it fun to figure out though. Then you get to be the dreaded PO.
