I am hoping to discover a simple solution to run the throttle sleeve, complete with cable and whatnot, without having to put that switch-pod on there. I was looking at mine the other day and it appears like you cant have one with out the other, hopefully that's not the case!
And if it is I won't be happy until I find an alternative solution to keep my bars clean. Do they make a self-contained throttle assembly where the throttle tube and cable are all inside a form-fitting little cover at the inside end? I don't want or need the switches up on the handlebars, so I'm open to all solutions. XS650 or aftermarket.
Thanks,
Logan
Thanks,
Logan
