maynard70
XS650 New Member
Allrighty, either I'm a moron, or I screwed something up, or both... I've read like three different ways to set and adjust the timing, and for some reason, can't make heads or tails of any of it.
So, I'll pose this as fill-in-the-blanks sort of questions if any of you gents can assist. These may seem like dumb questions, but forgive me, I'm sort of new at this.
Points being "open" means that the two contacts (upper/lower) are _______ (together/apart).
You're supposed to have current registering at the points when they are _____ (open/closed).
You cannot or should not have current registering on both sets of points at the same time. ___ (yes/no)
The right cylinder fires at the 'F' mark on the compression stroke, meaning there _____ (is/is not) current at the point.
Current should be present for 1.5 revolutions at each point for each cylinder before shutting off, 180* from the 'F' mark, while on the power stroke. ___ (yes/no)
I'm beginning to suspect I'm 180* off, but am not sure... If so, how does one fix this? I'm pretty sure the gaps are set correctly, and have filed and cleaned the points, but for some reason, the R cylinder keeps on registering current through the whole cycle. This is nuts.
Still a long way from being road-ready, but I'm plodding steadily along... I'm tryin'.
Thanx...... M.
Thanx...... M.
