funky
XS650 Junkie
Hi all hope yo are well
I have a question with regards to timing.
I have a Pamco fitted with standard ATU and stator 360 degree engine 533 conrods.
The book says that timing is set at 15deg BTDC does the and that when using the timing gun the ignition should fire between the "F" marks . The F Mark is at 15deg BTDC so if you have a timing gun with an advance feature you should set it on 0 deg not on 15 deg, is that correct.
all the best Funky
all the best Funky
