funky
XS650 Junkie
Are 533 cam shaft the same as 447
I have not shipped the 90 degree rotor for several years, so more than likely you already have the 60 degree rotor. Here is a pic of the two rotors for comparison:Thanks 5T and pamcoe pete the pin hole and pin are still there just have to fit the pin in the hole so what do i need to buy the E Advancer and what other parts do i need to change the ally disc which triggers the pamco from a 90 degree to a 60 degree
Well i did the Ton 5T.. but it did not come free i red lined it in first and second then when i changed up to third the rev counter went right round and touched the stop and i could hear what sounded like a coffee grinder i thought I blew the engine or broke a ring or clutch disc.Yes, so all you need is the E-Advancer kit. I would get one too if the original advance unit needed replacing.
