TCI was toast.
I’m interested - I’ve seen lots of welding done on vehicles which were essentially wired and complete with no ill-effects, but on the XS650, welding with the electrical system installed seems to be a big NO-NO.
How come?
Every manufacturer warns. Ask an exhaust welder about blowing modules, bet they can tell you plenty of stories.
Don't know why the TCI is SO sensitive but it is. Maybe some reverse direction current susceptibility designers weren't accounting for.
This bike was REALLY Billy-ized, very crude angle grinder work, seat mounts butchered away, frame tubes have big gouges, grind marks, handlebar controls filed "round", wires, cut, butchered, twisted, taped, crash damage.
Owner had replaced harness with one from my stash, Can't imagine how bad the wiring HAD been. A previous shop quit in disgust, LOL
So the basic drill, put in a known good battery, clean the frame, bolt mounting, install new ground strap, known good iggy switch, change throttle side control for one with working switches. Grease, lube throttle before assembling. Trace power with light bulb tester, it's getting to fuse box, then iggy on, tail light lights! We have some connections, more light bulb testing and find bad iggy fuse "holder", sub in a good holder from a junk harness.
Pull plugs, clean gap. check compression 100 lbs each side. (should run) squirted in some oil. I'm kinda lazy so starter next, nothing of course, big screwdriver, short the solenoid terminals, she cranks! Pull blue white wire at solenoid, ground, bingo! up to (missing) headlight bucket, shove small screwdriver in RH control connection blue white, ground it,
that works. I had tossed on a random RH control from the bins, Ground the control, double check ground from LH control, hit button with some rust buster, push n wiggle a few times, there we go, button now works. Put on a pair of spark plugs connected by bare copper wire. Start checking spark, NADA. pull coil connector use test light, red has power. Change one alligator on test light to ground, clip other to orange wire, crank, no pulsing light. Could be TCI, or something in triggers but seeing that welding, I go grab a spare TCI. BINGO. Nice bright blue spark.
Next up carbs, BS34s some one has busted off choke knob, bent the choke pull tangs, pulled them right off the choke plunger, NEVER seen chokes stuck that tight had to use my heat shrink gun for a while to soften the varnish,then it moved. I didn't even bother trying gas in carbs. squirt some Carb cleaner in throats and crank, get it to run! Pull carbs open bowls takes some serious whacks to break gaskets loose, floats stuck, varnish everywhere. Call owner leave message about $$ to fix these carbs, he says we're good, I'll do carbs.
Check oil, NADA! Both plugs loose NO oil, oops, tighten plugs, add a couple quarts, good thing I squirted some in cylinders before cranking! Assume nothing.
Hah it's out of my hands, whew go for barn ride on WJL it's great to be out.
