pnedac
Good afternoon XSers,
I bought a couple of bullet lights as brake light for my XS build, put a sheet metal screw into the bulb housing to replace the missing third wire (ground) and I am now stuck on why it is not working.
My brake handle (switch) has a green/yellow and a black wire.
My brake light has red, black, and now a yellow (I have frame grounded the yellow)
I put black from the brake lights to the black wire to the brake switch
I put the red wires from the brake lights to the green/yellow on the brake switch and I fed hot power to them from the same wire I am using to give power to the headlight.
I have used a test light and I see that I do have power to the red to green/yellow curcuit, but nothing in the black to black curcuit.
So there is where I am lost as everything is conected, but no power.
I also tried feeding power to both the black to black and red to green/yellow, but I got nothing when I hit the brakes.
I am lost because it seems to be right and is in accordance with the simplified wiring diagram on this site, but I have no brake lights. I have lights back ther, but no secondary (brighter) lights.
Any help or ideas would be greatly appreciated.
BTW I have fuses on everything so I would suspect that those would blow before I pop the light.
Thanks for any advice you can provide.
Pnedac
Pnedac
