R33Skyline
Ok so here is the run down. I recently cut my whole wiring harness to clean everything up because the previous owner did a hack job and my bike wouldn't start. So I rewired everything started the bike and to my surprise the bike started up. I followed the factory harness for a 1981 Yamaha Xs650 which is the year I have. So now the issues. I am having. I bought a TC Bros Model A Side mount tail light and cant seem to figure out the wiring on it. Here is the tail light that I bought. http://www.tcbroschoppers.com/headl...mount-tail-light-license-plate-bracket-2.html. When the bike key is in the on position, there is no running light, when the rear brake is pressed the bottom part lights up. The front I know why doesn't work because of a bad switch which is ordered from MikesXS and will be here Wednesday. Does anyone have a diagram I can try and follow or pictures that I could go by?
The next thing I am having confusions on is the headlight that I got from MikesXS which is the 7" H4 Halogen headlight. http://www.mikesxs.net/product/09-0074.html From the factory service manual it looks like two yellows get connected from the harness (Headlight dimmer switch and Reserve lighting unit), The green from the headlight dimmer switch, and the black to the ground. The wires for the H4 Headlight are different color, but the same plug type so I just followed how that was set up and nothing. Is there a way to diagnose this? Does the headlight only come on when the bike is on? etc.
Last but not least, the original turn signals will not work brand new just purchased from MikesXs. Everything according to spec. My last option will be to find and order a new harness but I wanted to try this project myself which ended up costing more in the long run lol. Thanks a lot.
