OakBehringer
XS650 Guru
Two questions:
1) Pete suggests using "standoffs" to mount the coil:
http://www.yamahaxs650.com/17-6903.JPG
I was unable to find this exact product, but I found some steel spacers of the correct length (see attached pic). Pete's standoffs are a bit more substantial, and I know the value of solid mounting the coil is to use the frame as a heat sink, should I bet worried that my coil might over heat?
2) My coil is touching my tank (see attached picture). It's not like... jammed into it (I didn't notice when putting the tank on, only when I looked from the bottom side). There is an inner bulge from the tank that runs along the top side of the coil. The problem is not that my spacers are too long - the screw on retainers for the plug wires are just touching the frame on the other side). Has anyone had this issue? I thought there was going to be about a 1/4" of space there. I'm a bit worried about rubbing the rubber coating on the coil off with the inside of my tank. Thoughts?
Thanks!
Adam
Thanks!
Adam
