So here are the particulars- '74 TX w/stock carbs(or at least 74-75 style). Left side is a dream, idles steady, quick response(I can open the throttle plate on each carb individually, they are not tied together). Right side does not fire at all at 1200 rpm. If I open the throttle on the right side, it will fire intermittently and puff black smoke until the main circuit starts kicking in, then revs right on up. On the road the bike runs fine above 3500 rpm or so, rock solid. Mix screw position has no influence. I have good, hot spark to both plugs, timed correctly, and the battery is new. Right side exhaust smells super rich as well.
The backstory- Right side carb has been giving me issues since I started riding the bike. Cleaning and inspection revealed that the pilot jet was all buggered up where someone tried to remove it. Carb also had the wrong needle in it, but that does not concern the idle issue. I tried every method I could find to get the old pilot jet out, but no joy. I finally chocked it in the drill press, and drilled out the old jet and re-tapped/chased the hole. The new jet threaded right in. It is the correct BS30/96 jet, size 45. Also replaced the floats in both carbs as they both had a wee bit of fuel in 'em. Set the new floats at the 24mm spec. Replaced the O-rings on the needle jets.
So- I'm guessing that I got out of shape with the drilling/tapping of the pilot jet, and excess fuel is somehow getting past the jet w/o being metered through it. Or- is it possible my new O-rings around the needle jets are problematic? Not sealing properly?
Finally, because I haven't pulled the carbs back off yet to check, will the bowls interchange side to side, or are they mirror image? Be nice to swap the bowls and see if the issue follows them. I have no reason to believe my issues are within the main carb body, but maybe I'm missing something. Thanks for any insights.
