Utah winter build
tscacadc
Layton, Utah
I got my first XS a couple months ago, 1975. I need something to keep my busy over the winter. I ski but I can't afford it any more these days. I hesitate doing a build thread but I have enjoyed all the build threads I have looked through so i thought I would try to contribute. The forum has already been a big help and I am sure will continue to be over the next few months. I am going to be taking my time, busy with a son who races areacross and all his motorcycle problems. So here we go.
What I am starting with. It does run, but badly. The brakes dont work and leak like crazy.
Starting the take down
Dont know where this came from but it looks ridiculous.
Proper strip
Fuel petcocks cleaning
Big dent in the tank, not sure what do with it...
Cleaning the carbs
Got the wrong gasket. Its a 75 bs38.. i thought. But I guess I need to order the next year choke gasket. 8 hole?
Got some progress
Got the key mount done
Petcocks and Carbs rebuilt
Signal light/running/brake mounts
Finished strip down
Getting ready to muriatic acid the tank
Your gauges are not XS650 parts, not sure what they came from. The 75 had a dash panel that the gauges mounted in. As well as the key switch.
Forks before
And After
Spokes taken out
Parts ready for powder
Little extra support added for the seat... maybe over kill but I had the stuff.
Lacing ...3rd attempt:laugh:
Lacing front
Truing
Tank finally done after about a 100 coats of primer sprayed on and sanded off.....
uhhggg, I hope i dont have any bolts left over
Swing arm with new brass!
Finally got the rear end put together
Forks back together
Head set in with new roller bearings!
Got the tires mounted, wow that was not easy, even with a proper tire machine.
Spraying the front disc holder
Got the front while ready to go on!
Finally winter seems to be coming to an end around here. I am starting to get more and more excited to ride this thing. Last couple have weeks a bunch of stuff has come together, here is how she looks now.
Forks rebuild and new rear shocks
Got the wheels back on
I wanted to make sure i got the engine home without major damage. Haha.
New PMA (thanks Hugh) Didnt get it on right the first time but Hugh helped me out.
Finishing up the cases, polishing took all the paint out so I dripped it back in slowly.
Buttoned up the engine
finally got my seat back. Took 2 months... turned out better then I hoped though. I really like it.
getting ready to put the engine back in the frame
now on to wiring....
