I have looked and looked and cannot find any references to the correct valve spring shim orientation. The shims fitted in my SH have two different surface profiles. On one side the shim is perfectly flat with sharp outer edges, the other surface is rounded on the edges.
PS. I have checked the manual but the picture quality is very poor.
- Which of these surfaces should the larger diameter valve spring contact?
- Does the shim rotate against the aluminum cylinder head, or should it stay locked in one position?
