Sundie
Jabroni
the cams are definitely different for the pre-447 models. And if you have a cam that doesn't have a "447" stamp on it, then you may or may not have a 447 cam.
Let's see if i can make a chart:
pre447 447 mike's performance
47BTDC 36BTDC 26BTDC inlet opens
67ABDC 68ABDC 66ABDC inlet closes
60BBDC 68BBDC 60BBDC exhaust opens
41ATDC 36ATDC 32ATDC exhaust closes
So, for pre447, the valves are open longer, with 9 more degrees of overlap. And the Mike's one is obviously a high revving one - lookit how short that intake opening is. But it probably has a higher and more drastic lift. Actually, looking at it, i bet it doesn't idle well, and you'd have to get big ass carbs for it. Meh. If i had a choice, i'd probably run the pre447 if it was otherwise identical to a 447.
As for adjustment - no, it's not something the general person would think about, nor can you adjust it. But it's an easy way to tell without your engine apart if it's time to replace your cam chain. If you can't get close on the degreeing without excessive lifter adjustment, it's time.
John, how do you "move the cams"?
