Hey guys...now this one will be hard to explain without pics but try and follow me here.
I have a 1999 Gsx-r 750 front end. In order to run my spoked rim I need to swap wheel bearings...pretty straight forward right...wrong!
The bearings don't exist, they can be made custom but are asking an unearthly amount for them...which I expected to be the case.
Now another member on here and I recently worked together to come up with an adapter that would allow him to run a different caliper with his brake setup. All it was was a spacer with a bolt hole pattern essentially.
What I think I am going to do...is order the stock gixxer wheel bearings, make two more of these spacers, except instead of clearing the middle, I will bore them to fit the gixxer bearings.
So if you're still following, the spacer will bolt to the hub, where to rotor normally does, it will have a bolt hole pattern to space out the new rotor, but it will also house the wheel bearings.
My concern here is staying concentric....which I believe I can achieve by simply bolting one spacer on for boring, and clamping directly to the hub in the lathe chuck. My next concern is using strong enough bolts which shouldn't be too difficult to find.
I just wanted to throw this concept out there to see if anyone could think of any other potential issues?
I've seen this done before so i know it works, but any input is welcome.
Thanks
Thanks
