Roto36
My 77'D has a fresh rebuild from previous owner. When I got it all I had left was tuning carbs, paint and few miscellaneous things to finish. While getting help from members here about my carb issues it soon lead me to check my compression. It was off the chart at 240 psi both sides. I had no reason to check what was in the jug until now. I found Venolia pistons inside with over sized sleeves, after some measuring I'm at 800cc and have a little over 12:12 compression. With help from grizd1 I learned how to lower my compression so I can run regular pump gas.
I checked around with my local machine shops to have material removed from the tops of the pistons to increase volume and lower CR, some shops say they're not setup for this work and another strongly recommend I leave these pistons alone because they're not something you come across everyday. One shop actually said "shaving these pistons is like taking a distinguished lady and knocking her teeth out so she can perform better" (made me chuckle...!). I'm sure it's no problem to find a machine shop to work on these but after learning more about these piston I'm having second thoughts.
This shop recommended I find a jug with matching pistons instead of shaving these. This way I can always increase things as they wear out.
So now I'm at a road block of options to consider.
- Thicker gaskets and take what I get and use octane booster?
- Find a shop, shave the damn things and move on?
- Find a matching stock jug with pistons? (What years interchange?)
- Keep or sell the jug with Venolia's?
Not wanting or needing a hod rod bike, just a cruiser for occasional overnight road trips.
Any ideas/advice would be much appreciated!
