I have a set of aluminum intake manifolds I bought on ebay. You have probably seen them before. They are quite a bit longer front to back then the stock XS rubberish intake manifolds. The length won't be a problem as I don't run the stock airbox. I think they run about $60 on ebay. I was going to use these intakes with some VM 34mm Mikuni carbs. Has anyone drilled and tapped these type aluminum manifolds for nipples so that the carbs can be sync'd? If so, at what point on the manifold did you drill?
jefft
jefft
