I have a 1978 xs650 special with stock pipes and uni pods. Does anybody have a similar setup around st louis that would be able to tell me what jets they are using? Would like to get a good baseline before i go crazy ordering jets.
Thank you. Ive got 15 pilots in at the moment and it seems to at least idle alright. Might have to go up once I really try to tune it innichecycle is good.
hot cam 750 is set like this at 950' ASL.
Carb: VM34
MJ: 180
PJ: 25
NJ: 159-P6
JN: 6F9, 3rd slot
Slide: 2.5
Air jet: ?
Float valve 3.3
Check your slides. VM34s leave the factory with #2.5, but some tuners and aftermarket vendors install the richer 2.0. There's an inverse relationship between slide and pilot jet. With the generic 2.5 slide, a 22.5 or 25 PJ is the usual choice. With a 2.0 slide, a leaner pilot jet,17.5 or even 15.0, is called for.
Jet lists are nearly meaningless unless every last piece of brass in the carburetor is accounted for. Guys, let's put more effort into teaching how to tune than telling what to buy!
Ive got the 2.0s. So that would explain why the much smaller pilot seems to be working my pin setting is also in the 3rd position. 180 main jet 15 pilot
So, what slide do you have?
Ive got the carbs from tcbros. I believe the needle is a DH9 or something like that. Jet to matchNeedle and needle jet are very important. If you have generic off the shelf VM34s, the needles and needle jets they came with probably need to be changed. Also, most run with the air jet removed.
