I wasn't specifically saying that you have an ignition problem, only that many others blame the carbs for their problems when it's not really the cause. I wish I knew what was wrong with your bike, lol.
evenmorexs,
With that date of sale, you have a 60 degree rotor which we have been shipping for about 4 years. So, the dwell area is in between the magnets 60 degree arc. During that dwell time, the coil is turned on by the transistor, so the voltage as measured from the battery positive terminal to the coil + terminal (red wire from PAMCO, red / white wire from the kill switch) will be at its highest and that is the Voltage of interest.
How does .623 v sound? Measured in the dwell. Here is a short vid of me rotating the rotor, just so your sure I set it up right.
OK. That's a very good but believable number. Other ignition issues to check:
1. Measure the resistance from cap to cap.
2. If you have resistor caps, like 5 K, then that adds up to 10K plus the secondary resistance of perhaps 12K to 15K for a total of 22K to 25K ohms.
3. The purpose of the cap to cap test is to ensure that one of the caps is not open. If one cap is open, it affects both spark plugs because they are effectively in series. The high voltage can jump the open, but the result is a weak spark delivered to the spark plug gaps.
Evenmore,
Wait...you can't do that! What about the rest of us who are trying to help? You can't just leave us here! LOL
Give it a rest. Go have a beer or two. Go to the movie with your lady. Relax...
When the idle starts racing, can you push down on the cable arm where the cable connects and get the RPMs to drop back down? If so and you recently replaced your butterfly shaft seals, then maybe the butterfly plates are not centered properly in the main bores and they are binding.
Look at the beginning of your video. Press down on where the cable ball end hooks into the arm. You could also lift the other end, where the idle speed adjustment screw contacts the arm. You're attempting to close the throttle plates back up if they are indeed hanging open. You could also look at the cable arm where it meets the adjusting screw. Is there a space there when the RPMs hang? If so then the plates are not closing fully.
You've checked the advance and it snaps back closed smartly when you twist it open by hand? Because if your advance is sticking in the advanced position, that's going to make the revs climb. If your idle speed is set too high, that can start the ignition advancing, which raises the revs, which advances the ignition more, etc. It's sort of a "self feeding" problem.
It almost seems like the bike doesn't want to idle at all. That would point to problems with the pilot circuit (like it's plugged). When you screw the idle speed adjustment in enough, it opens the butterfly plate so much that you're running more off the needle and that's just too fast. Then the advance gets going, adding to the problem.
