Suddenly my motorcycle has been running like **** below 3K RPM, I am thinking it is the carbs but want to know what you guys think before tearing it down.
Seems to be charging fine (will test volts when I get time), although when I turn on the blinker and hold the thottle open, the engine revs in sequence to the blinker. So if not carbs possibly issue with charging or timing (i.e. TCI going out....?).
Right cylinder spark plug is fine, maybe a pinch lean; left cylinder spark plug has a bit of carbon but not an amount to warrant carbon reading from spark plug chart.
I've ran Seafoam through in the fuel but no improvement. Didn't really start acting up until I fueled up at a hole-in-the-wall gas station (was in a hurry) and set off on the same 40 mile ride that stranded me last time
Accelerates fine above 3K RPM but if I let it go back to idle (i.e. traffic light) I have to sit on the throttle and rev it until it "clears up" and let's me go again, otherwise it just bogs down very badly. This is why I think it's a carb issue.
Using the blinker causes a loss in power, which may point to a charging issue. But as you guys know I resolved previous problem. Unless my original VR just went out, very doubtful.
I have a timing light, even though this is TCI should I check rotor timing (i.e. maybe I moved it out of timing when I replaced)? My bike is an 80G.
The bike is driveable but it's very annoying and I know it's not good to leave issues unresolved. Thanks.
