Sundie
Jabroni
Looks like the guide to me........ all those parts went through the oil pump so I would check that for possible damage ....sump filter also....... xsjohn
I thought the oil pump was downstream of that filter - Am i wrong?
Having a release valve is a good idea. If a blockage occurs oil can still flow.
If the release valve is at the sidecover filter, if it gets blocked, the filter is bypassed and oil can still get to the rest of the engine.
If you keep your oil changed and filters checked, this will probably never happen.
If you neglect the oil and filter and the filter gets blocked, bypassing the filter may not help, it may be to late.
It may not help but under some conditions it may help prevent excess damage.
