We're off to see the Wizard!
I received a cylinder from Gary today (that needs boring). I started calling motorcycle shops and found out that no shops around here do bore jobs. Does anyone know anyone that does bore jobs near Atlanta? The shops I worked at in the 70's always had a boring machine.
Bill
I am getting my GPz cylinders bored at Eagle Machine in Auburn, GA. They can go small enough to do the 750 cylinders so they should be able to bore the 650. Be advised, they are two months out... Talk to Bill Brady 770 339 3053
The second xs650 for Gary is getting closer. Got the engine in today.
The bike did not come with a center stand. I did find one. Just found out I put the wrong bolts holding the center stand to the frame. They are too short. Did Yamaha make different lengths? Now I have to find the longer ones and then replace them. What a pain but I am learning stuff every day.
Anyone seen this stack up on the Kickstarter shaft? The parts list I have does not show these parts, just the flat washer between the shaft and case..
Was looking back and saw this. @BowlingSS 000146 also has that thrust bearing 'tween the kicker and the cover.
It also lacks a snap ring to hold all the kicker parts together on the shaft like the later bikes have, takes a bit more fiddling to get it all back in place to fit the cover.
70-73 center stand bolts are longer because they also hold the mufflers on. I have a pair of the longer bolts. PM me if interested.
Bought this bike home from North Dakota long ago mainly cuz some paint chips showed green. ;^)
twas a bit rough
It went to see Bill this spring mostly looking like this;
and he graciously sent back the headlight bucket and ears.
Got busy with some acetone today, when I started,
and finished
Debating touch up or leave as is...
Have some green sidecovers also
also a bit "experienced".
Still need a tank and shock covers in original green. Been beating the bushes for a tank for a long time with no success so far.
twas a bit rough
and finished
LEAVE IT!
