I am new and i finally decided on my next toy being a cheap around $2000 xs650 bobber styled bike. its alot cheaper than driving my car around gets around x3 better gas milage and is relativity cheap as long as i get a good engine etc. i'm only 17 and by far not a mr good wrench but i can do normal stuff like change oil and air filters and tires etc on my car and i even put my own cold air intake on i was so proud. but what are some basic tools i don't have much money so i need the basics nothing special and i know someone who is a decent welder. this is my first bike so it won't be anything special most likely just matte black with a tachometer because i need one of those being new.
Here is my advice, if it sounds harsh at time its because you need to walk before you run.
You won't buy a running bobber that is reliable for $2000.00 without some major work and time off the road, then you still have to buy the tools to finish/fix it for a reliable transport bike. Could be another $2000.00.
Instead of going straight for the cool look, a good condition and running XS650 could be found for $1500 - $1800, (remember i am an Aussie and only going off the prices quoted by the local lads), depending on your area.
Even a bike like above will probably need some initial work, or some on going maintenance, (carbs cleaned,swing arm bushes, setting points), small stuff but good learning. Keeping the bike original, (may want to swap bars or seat to do some minor visual improvements), means you will get to know your bike through general maintenance and will slowly build up a tool collection as you need it over time.
You get to ride to work, (except for some down time and learning experience), have time to decide what type of bike you want to build and time to save some money to be able to do it.
You are 17 and the temptation is to have it all now. ......With a little patience you can still build the cool bike you want and the cool thing would be the knowledge gained buy getting a good runner and learning from it by keeping it on the road till you have the parts and vision of what you really want to build sorted out. ......Then build it.
Buying a half built bike will be a drain financially and mentally, unless you have the money and time to do it, but from what i am reading you want something now that is going to be a financial, (Fuel), saving...........The Xs650 will still be a cool bike in its original form, a lot of the oldies will be pestering you with stories of when they or their mates had one.
Some tools before going to look at a bike.
Compression tester,
Volt meter,
Fully charged new battery.
Some punters will say it only needs a battery, was running. You will weed out some of the liars when you tell them you will bring your own battery and do a compression and rotor test.
Read these 2 articles, and the post from INXS down a couple from mine in the Guide to buying
1
2
Read and get to know them, although they are more for after you have bought a bike there is a lot to be taken out and used for checking out a bike.
A set of ring and open end spanners, Metric, 10mm to 18mm min and may have to but a 6mm and 8mm separate, Gauges).
A good set of screwdrivers.......here i will differ on buying an impact driver.......spend the money on a set that has a full shaft through the handle and they can be used as/ instead of the impact driver. Better reach and the screwdriver set i have are guaranteed not to break and can be used as levers as well.
Agree on the rest of Downeaster list. A 12" adjustable wrench would be handy, but as Downeaster says buy a good one. How to tell, the adjustable jaw should have very little play, (some but minor), when you try to move the jaw backward and forwards. Go and test between a good quality make and an obvious cheap one and you will see what i am talking about
Good luck with you endeavor.
