Iirc, #3 is the starter cutoff In case you accidentally bump the button, it won't spin the starter when the engine is running. The other two things are relays, headlight and maybe horn?
#3 is the safety relay, controls headlight and starter over run. #1 is the sidestand starter interlock relay from an 82-83 heritage. Not sure on #2s original use but it's also a relay. If you are doing a bobber or other custom they won't be used.
Thank you, yes XS650SJ 82', I build the bike and trying to understand what need and what is not, I use the starter and battary.
Well, these relays are not important, besides #3, I understand.
Ok.... it is important...
I started to dismantle the wiring took electrical tape and began to separate the elements necessary to me and wires, found the scheme of my bike ...
Everything was still confused ...
I can not identify what I need to work a starter?
Can anyone point me in the diagram that I need for a starter from the old wiring?
