YamaHopper
OK, Here's the bike:
1978 xs650SE "Special"
POD Filters (Carbs ARE re-jetted, new manifolds, float levels, etc...)
New Headers/Tapered Mufflers from MikesXS
Still running points (replaced last year)
All other MODS (and ther are a lot) are primarily cosmetic.
OK, Here's what happened:
2 weeks ago-bike was running great but the elec starter would not turn over the engine (ALWAYS worked in the past). You can hear the elec motor spin when pushing the start button. The engine would fire right up wth 1or 2 pumps of the kickstart.
A few days ago-was out for a cruise along which Imade 2 stops. Engine kicked over no problem bot times. Was on my way home (exactly 1 mile to go) sitting at a traffic light when it just quit on me. Engine just turned off. No strange noises at all, just as if somebody had hit the kill switch. I could NOT get it re-started (and of course now it's starting to rain-HARD) Elec start - still just motorwhine, Kickstart - the kick lever DOES have recoil at all times. If I hold in the clutch, kick pedal goes own with no resistance like a dead fish. If I kick (in neutral) wth the clutch lever released, has good resistance. Alternator - remove cover, turn with wrench, feels good.
OK, Here's what I checked
Try turning crank by way of Alt, Engine turns over (w/ or w/o clutch grip in or out)
Pull Plugs (1 at time), thumb over plug hole, crank engine feel for compression: left side-yes, right side-yes
check each plug for spark: let side-yes, right side-yes
Put bike in gear, kick over, bike lunges foreward: clutch grip out-yes, clutch grip in-YES (should NOT - correct?)
Put bike in neutral, kick over, bike lunges foreward: clutch grip out-no, clutch grip in-no (w/ clutch grip in kick has ZERO resistance)
Open tapit covers, turn engine over by way of Alt., valves go up and down?
Left Intake-yes
Left Exhaust-yes
Right Intake-yes
Righ Exhaust-yes
Left Intake-yes
Left Exhaust-yes
Right Intake-yes
Righ Exhaust-yes
