I've got full access to a salvaged 1998 Yamaha R1 which has good electronics, wiring harness, regulator, rectifier, flashers, engine, carbs, forks, wheels, complete front and rear brakes, hand controls, front and rear master cylinders, clutch, stator, etc, etc.
I know their are a lot of new modifications to the xs650 due to the it being more than 30 years old. I know the Yamaha R1 I have has a lot of items which are usable on my xs650, but I'm not sure which actual pieces are compatible.
What I'm trying to do it is eliminate the following:
Thanks for any help you guys can give.
- Eliminate the stock turn signal flasher. - Can I use the R1 flasher as a replacement?
- Eliminate the stock hand controls. - Can I use the R1's?
- Replace the stock separate regulator and rectifier. - Can I use the R1, 3 phase regulator/rectifier combo?
