gps2
And what does it do? On my '75, it has green/white, yellow and black wires and is a small grey box about 2" long. Do I need it? If not, how can I bypass it?
Posted via Mobile
Posted via Mobile
The light checker of the 75 B functions to "check" that the stoplight is operational and if not to inform the operator of same by a indicator light. Many people choose to remove this unit viewing it as one of the unecessesary "bells & whistles" that crept in over the years like the self-cancelling turn signal unit, the reserve lighting unit and the sidestand interlock unit of later years.
....sorry - hit send too fast. I note from the wiring schematic above that the Reserve Lighting module is not shown (the diagram is for '75 "B" and '76 C-models).
Hmmmm - other sources indicated that ALL years of XS650's had this nasty little bugger lurking under the seat somewhere......
The RLD was first used at about the same time that the law required a headlight to be on during daylight hours. The main purpose of the RLD is to switch over to high when the low beam fails, which would not be noticed by a rider in the day time hours. I agree with 650skull, keeping the headlight on, during the daylight, could save your life.
I consider the RLD, Safety Relay, and even the Light Checker as worthwhile devices. However, the side stand switch, clutch switch and self-cancelling turn signals, I see no value in them. In fact the self-cancelling feature is dangerous, because it can often cancel before the turn is completed.
