blackbetty
XS650 Junkie
- Messages
- 786
- Reaction score
- 12
- Points
- 18
OK. Can someone explain what's going on during a pop stall?
I seem to have had this issue since the day I got my bike, even with the motor in stock configuration. I put on a 700 kit and a shell 1 cam, and the problem persists. I am working with a factory deck height with both head and base gaskets.
I was working with my 76-77 BS38s trying to get the bike to run, but unless I ran a huge pilot, (35+), I couldn't get a decent idle.
I have since switched to VM34s, and while the mid and high circuits feel strong, the idle is just so finnicky. My VM34s are from MMM, 210 MJ, 30 PJ, 6F9 in 3rd position, P-6 NJ. I have my mix screws out at 1.5 turns. She wants to pop stall randomly at lights (annoying), and I have also found that when I'm coasting to a stop the engine speed will drop and sometimes the motor will die. I assume this may be a clutch drag issue pulling down RPMs, and that's leading it into a stall.
Plugs have been making me feel like things are on the rich side, I attempted to drop the needle and fatten the mix with no change. The video is with the clip back in the middle slot.
Manometer shows each cylinder within a half inch of each other. The levels will oscillate from side to side during the idle ab an inch but will usually level themselves out after a few seconds.
Here's a video, first "pop" at :11, 2nd one kills the motor.
I also found this video of this stocker doing the same thing:
