blackbetty
XS650 Junkie
- Messages
- 786
- Reaction score
- 12
- Points
- 18
So here's where I'm at.
Kop tells me I need to measure piston/head clearance at TDC and presented possible scenarios. I'll take his advice and take a wax measurement through the plug hole. I know I have no piston/valve clearance issues, we're trying to figure out if the squish is adequate. He also told me to fix my too long exhaust by cutting at 32" or inserting a reversion cone of some sort at that point of length.
I also called Roger at Hoos, who did my machine work. He tells me adamantly that piston/head clearance on my setup is probably somewhere around .008 to .01, which is plenty adequate and wouldn't be contributing to my issue given his experience building 700s and 750s. I did discover that his jetting for his 750 race bike is exactly the same as my 9.5:1 700cc street bike. Obviously, per griz's suggestion, I'm almost certainly overjetted. To put the piston/head clearances into perspective, Roger tells me his 750 race motor is at .005 and really maxed out in terms of what he can do before harmful piston/valve interference occurs.
So then I spoke to MMM. He sad to pull the air screw out to 4 turns to check on the performance. I'll give that a shot; in the meantime I ordered 25 pilots and 200 and 205 mains to have on hand. He also told me that running the base gasket and keeping at 9.5:1 isn't really letting me take full advantage of my Shell 1 cam, and that idle on these will naturally need to be raised given the cam specs. Makes me wonder if I should have gone higher on compression. He also told me to increase my plug gap.
So, I'll order some wax and do a squish measurement under kop's suggestion, and while I wait for the wax I'm going to play with the carbs and open the gaps a bit.
