mconigliaro
Hey guys, I just bought a pretty heavily customized xs650 with an unknown set of wheels. I took it to a local shop to have them look it over, and they told me it was time for a new chain and sprockets, but I'm not sure what kind of wheels these are, so I don't know what kind of rear sprocket I need. The guy who did most of the work on this bike is not the guy I bought it from (and I'm still trying to get in touch with the original owner), so you guys are pretty much my only hope for now.
For what it's worth, here's what I know:
I'm hoping "other parts are stock Yamaha" means I can just go with a stock xs650 rear sprocket.
Thanks in advance!
The "H" model originally had a 19" spoke front wheel combined with a 16" spoke wheel in the rear. The rear was also a drum brake. Both wheels have been replaced with matching mags that have a 19" front and 18" rear..both discs.
Rear disc brake conversion is by no means plug and play. A disc brake swing arm with the brass bushing upgrade was installed instead of the stock nylon ones. This also helped the handling. Rear wheel had to be modified with conversion bearings and spacers to stay with the larger 20mm axle. Precise measurement and fitting to assure correct chainline and tracking also necessary. More spacing required for the disc brake. A lot of work but worth it to get rid of the 16" chopper rear. Calipers, master cylinder and other parts are stock Yamaha for ease of replacement if ever necessary.
Thanks in advance!
