Somehow my chain decided to rub through part of my case and exposed this hole with what appears to be an aluminum plug. (I found it resting below my sprocket in the left cover). Then I go to put it in the hole to make sure that is where it went then I couldn't get it out. So for some reason I decide to go ahead and push it all the way in. Now there are two holes which are half covered by the end of the plug. Are these holes some kind of oil passage? It seems as if they would have been covered up before it fell out.
I run a 530 chain and according to my manual every part is accounted for so I'm unsure why it was rubbing.
Any of you ever seen this before? I'm unsure of how to fix it.
