Cougar
Hey electrical gurus.
I have just finished soldering up my electrical system. PMA & capacitors. I ran the ignition circuit during a mock up, now with the soldered complete system I'm not getting spark. I will test for continuity on my next set of free time. I changed the leads to the capacitors since the mock up as well as glued the fuse block to the inside of the electrical housing. Here is a basic drawing of the electrical system as it stands.
What I am wondering is, if the leads to the capacitors are soldered together in what is essentially a "Single wire" will this cause the capacitors not to charge? This "Single wire" is illustrated in the real life photo
- I had each wiring connected individually. This is the only major change since the mock up that I can think of.
Any help sincerely appreciated!
