which model is suitable for a street tracker?
londoncabby
Essex England
Hi all just found this great site after trawling the net looking for info on building a street tracker,I'm currently searching for a doner bike (xs650) but there hard to find here in England, I've seen one I'm interested in its a 1980 650 us custom(chopper style) would this
Be suitable to use as a doner? What model do you guys suggest is best, I don't want to
spend my hard earned and then find out its not the right bike, definitely an inspirational
site!!:)
Hi cabby,
an '80 Special will work OK for a tracker conversion.
Not that earlier models won't work too, it's that the earlier models command a better resale value so long as they ain't been molested.
Basically what i need to know is are the frames the same on all the models? the bike i'm interested in is on Ebay and i need to find this out before i place a bid!
Hi cabby,
Hi fredintoon thanks for the reply, our posts crossed and you replied while i was sending my second post.
A special with rear disc brake is best IF you want a rear disc brake. A standard takes a little more work to mount a rear master cylinder, again only if you want a rear disc brake. The other difference is the special top rear shock mounts are a little farther forward on the frame, making the shocks angle more vs a standard frame with a rear drum brake
Thanks for the quick replies guys thats really helpful,after reading about some of the builds on here especially pregrids i can't wait to get started.
