The Standard tank is larger, about a gallon more. Supposedly they'll fit right on a Special. 1979 and older tanks will have two petcocks as opposed to only one on your stock '81 tank. That's not a big deal. You can plumb both to a "T", then down to the single fuel inlet on your BS34 carbs, or block one petcock off and only use one.
However, there is a small downside to blocking one petcock off. That side of the tank won't drain fully. When Yamaha went to the single petcock tank, they redesigned it internally, lowering the area at the rear so both sides could drain out the one sided petcock better.
