Nooovie
So I've made the mistake of deciding to go Harley wheels on my XS. Now, I've read through countless of threads on various forums, and seemed like a pretty easy conversion. Easy... yes, if you have all the right info. Inexpensive... well, it could be... again if you have the right info. Unfortunately there is not one definitive write up on the swap... yet. That I have been able to find anyway. Well, I hope to put something together when I'm done for anyone undertaking the same swap.
Ok, I have my front brake on the springer pretty much resolved. But I need some serious advice on how to set up the rear.
I have a TC Brothers hardtail section, and now have a 2000 Dyna 16x3.0 rear wheel. Looking at pics of other XSs with HD wheels, I purchased a one piece rear calliper of of a 2003 FLT Road King, thinking it was the same (because at first glance it looks the same) as a Softail or Sportster caliper. Looking now at pictures of the two, I notice little differences. The one on the left is a Softail caliper and on the right (or below) is the Road King Caliper I have. The stem looks way thicker on the Road King now that I look at it...
The problem I am having is that my wheel will now not center, because the round part of the caliper bracket mount that goes around the axle on the Road King caliper is over an inch thick. Are the early Softail and Sportster mounts thinner? Without blindly buying one on eBay, I don't have access to one. Could someone measure the thickness of that part? or explain to me the differences between the two calipers? Are the Softail and Sportster calipers the same? Does anyone want to buy a Road King rear caliper?
Thanks for any info
Thanks for any info
