barelycompetent
81 XS650 Special
Ok so I have been putting some miles on my bike after getting my carbs cleaned up and the bike running really well. I started at 45 pilots, and 137.5 mains, 3 turns on the screws and the bike ran and pulled really hard. At highway speeds when I grabbed a handful of throttle to get around someone the RPM's went up before grabbing and taking off. So checking my plugs they were white, and running lean. Had about a 100 miles on them by then so I moved up to 140 mains. Same thing, but a little bit better. 100miles or so that way, went to 3.25 turns on the screws and still running a little bit lean. So the other day I put 142.5's in on the mains and went for a spin. Grabbed a handful of throttle at 70 miles an hour and still had the same problem, RPM's go up, then it kicks in and takes off. Pull the plugs and they are white. I should also mention that I do have one shim on the needle, the carbs are bs34's and I have followed the carb guide. I am now 3.5 turns out on the screws and same thing, still running lean by the looks of the plugs. The weird thing is each main jet, 137.5, 140 and 142.5 all ran really well with them, and pulled hard, each one pulling a little bit better then the last, but still I am lean. I dont want to go anymore out on the screws and I hesitate to go another size up on the mains, for one I dont have that size lol, and two I dont know that it needs to go that high. My float heights are dead on at 23mm. My bike cruises along at 70mph with no problems, the RPM's are only about 4-5k, its when I grab that handful of throttle I get that little burst of high RPM's before it kicks in, and Im still lean. At idle I can pull the plugs and I have the nice light tan color on them, but under load and at mid and high range its white and lean. Could I be lean in my midrange? My needles are the non adjustable ones which is why I have one shim under them. Any thoughts? Sorry for the long post and I appreciate the help, Im out of ideas on this one.
