I put 35mm forks on my XS2
Before
After
I pressed the stem back through the lower triple until it was the same length up top as the XS2 lower and stem, then welded it there on the bottom side and swapped the whole thing on using tapered bearings. I also swapped on the longer swing arm from the same '79 Special.
