first of all I've been on the site since I started restoring my bike and have to say that you guys have been incredibly. I have gotten a lot of great information from reading through the forums and tech section. I found the specific model of my bike and have been looking to simplify the wiring on my bike since I have removed the starter entirely since I have bought and installed the PAMCO ignition with the high output coil. I was hoping if you guys could help me out with the electrical a bit and let me know if everything looks good or not. I'm assuming that the third wire coming from the original will not exist anymore since I am running the flasher relay from mikes which doesn't have the cancellation in it. Am I right in assuming that the left over wire from the headlight fuse needs to tie into the yellow wire of the headlight?
This may be a totally rookie question but as you'll notice I removed the relays from the diagram. I've been discussing the issue with a friend and after reading through the forums I've gotten the impression that I can remove the relays if I make the new wiring harness with 14 gauge wire as it can handle the current.
I posted the original diagram as a reference so that you guys don't need to chase it down.
Here's the one I've modified:
