cyclejunkie
Louisville KY
Hello,
Not very good at the wiring side of things, looking for a little help, sorry for newbie question..Thank You For Your Time
Have a few questions on current build. I am starting from scratch on wiring. questions on the Chrysler/Radio Shack Rec/Reg...My build will be a basic setup, kill switch (ign hot), push button start. Running just head/tail lamp.
1. I have built and wired setup and is ready to be mounted.
2. It is a 81 rotor/stator with original 6plug, will be running pamco ignition.
(3 white, 1brown or red,1green,1light green or blue) then 1 yellow bullet female connector. 1 light green with black cap cover.
Questions;
1. Where does green wire from Chrysler Reg connect to?
2. Where does brown wire from Chrysler Reg connect to?
3.on my stator, I also have a 3 plug connector/ orange, black, grey...what is this for?
4. What is the yellow bullet female connector for?
5. Red from RS rec...goes to main fuse?
Questions;
