Absorbed Glass Mat (AGM) batteries are the latest step in the evolution of lead-acid batteries. Instead of using a gel, an AGM uses a fiberglass like separator to hold the electrolyte in place. The physical bond between the separator fibers, the lead plates, and the container make AGMs spill-proof and the most vibration and impact resistant lead-acid batteries available today. Even better, AGMs use almost the same voltage set-points as flooded cells and thus can be used as drop-in replacements for flooded cells.
Basically, an AGM can do anything a Gel-cell can, only better. However, since they are also sealed, charging has to be controlled carefully or they too can be ruined in short order.
