Don Burgoyne
Powerage496
Newby question, sure it's been asked before, can I use later model intake/carb holders on my XS2 for use with a vacuum gauge to adjust carbs?
Don Burgoyne
Don Burgoyne
also will this work on my XS1B too?
Don
Don Burgoyne
gggGary, you're correct, there are spigots for a hose that links the intake tracts on XS1 and XS1B heads. It shouldn't be much of a challenge to remove the hose and plug the spigots for tuning, though; just install two separate pieces of plugged hose.
You can drill and tap under the intake on the head for a barb as I have done on my 72. I used a small 90 degree attachment and modified a bit to fit. Then tapped by hand without taking the engine apart. You do have to take the carbs off.
Take a look at this post and it will show you where to drill and tap. I posted some pictures a while back but I can't find the post. Copy this and past it in search.
Question on carb holder air barbs
I will post some pictures of mine tomorrow.
Probably no more than the later models with the molded port on the rubber holder.
