mortenraun
Hi Everybody.
First of all i have to apologize for my writing skills. English is not my first language and my problem is fairly hard to explain.
I am riding a XS2. I have fitted a hydraulic clutch slave from a Kawasaki ZRX 1200, with a Nissin 16mm master. I was running fine for 10.000,- km. Then i was going to change my clutch plates with a new set from Mike's. And fit a new Brembo Serie oro 16mm slave. With a bit of hassle and adaption I got it all fitted and ventilated. Now when the bike is off. The clutch is engaging and there is full actuation.
But when I start the engine the clutch "looses grip" momentarily and doesn't actuate. After about 10 seconds "preassure" builds again and its able to disengage once again. I took the bike for a short slow testride and once the same thing happened again.
I have checked the hydraulic system several times and I can almost guarantee that there is no air in the system and nok leaks.
Does anyone have a clue what might be going on?
Once again thank you for a great forum and all the help I have been getting.
Kr. Morten
Kr. Morten
