Carburetor is freshly cleaned! I could barely get the bike to turn over, and when it did, it stalled if I didn't have the throttle open (even with the idle speed screw all the way in). I let it run like this for about thirty seconds then shut it off. Out of curiosity i felt the pipes after this: right pipe was hot, left pipe was completely cold, like that cylinder wasn't firing.
I considered using a test light to adjust timing, but my bike is an '82. No points!!
Another thing is that gas doesn't want to flow freely down the line. I replaced the vacuum petcock with a new gravity one, so there's no air line going to the carb boot. When the fuel line is removed, gas comes right out, so it's not a clogged filter. But when I clamp the line on, only a small amount of gas will come out.
Anyone have any ideas?? I need to get this thing running ASAP!
