My latest bike.. has JE700, Shell #1 cam, R/D spring set, New Valve guides and Kibblewhite valve, Ported head to match the 38mm Carbs and intakes, Powerdynamo Ignition( runs with no battery, TT pipes, Suzuki 185 tank, runs strong, Wiring is under the seat. I built for myself all the best stuff. Electric start parts were removed. 1st kick every time, $3750.00 will buy it. Will accept serious offers, the motor alone would be $3200.00. The motor was completely tore down I have pic. New parts top to bottom.
New Progressive Springs up front, New ALLBall Bearings, New Gremica master cylinder and new stainless break line.
Those are the good points, tank has a few minor dents that (the guy I had paint did not get all out, hard to see in most angle. I would put a new rim on the rear just for cosmetic if I end up keeping it. It is true and straight just not shinny. The key is for show only, never wired. Just didn't feel the need.
Also the picture of the front brake line is an old picture ,I up loaded the wrong one. It now has a braided line that fits right behind the fork. I will try and get that changed.
