RockingThePartyDJ
XS650 Obsessed
My "Retro Rocket"
I figured I should start a build thread for my Build Off Bike Entry since I want to have it done in no more that 90 days from now, since i've accomplished very little this shitty winter we had.
So with this in mind I want it done by the end of July so I can ride it some and make sure the bugs are worked out before the meetup and ride in August.
My plan is to get all of my fab work done before the end of May, Engine work and maybe enough wiring so it will run and test it out a little before the end of June, and then do the paint & Powder as well as well as get all of the final wiring done before the end of July.
If I can get more done sooner all the better.
I'm starting with an already Hardtailed 77 frame I picked up on Ebay as an unfinished project. I have sold off alot of things I did'nt want to use on any of my build's coming up and i almost recouped my initial investment.
This is how the frame started and i cut off n ground down the seat mount tabs n steering head lock I didn't plan to use them and cleaned up some other little bits too.
Here's where the frame sat in November before I cut off stuff i did'nt want.
I made My Rocket Headlight back in November and i picked up some Hyde "M" Bars.
Then December I picked up some COOL Posh Grips after I decided the paint scheme i will probably go with "Silver Metal Flake with Red Candy"
I was cutting off the tabs and grinding spots smooth on frame also in December and got metal in my eye as i posted in the build off thread in late december, all is good with my eye now but I pretty much left the build sit with very little progress till yesterday, other than i did make many key decisions for the direction as well as what parts to use and ordered many of the parts that i'll need.
I made a Rocket tail light to match my Headlight.
I mocked up my front forks with some Fork Covers I picked up a long time ago for another build. I also put the Hyde M-Bars on as well as rear wheel and space the Ford tire ring rear Fender and checking placement of my Cole Foster tank I picked up awhile ago too. I need to cut the front fender to make it skinnier to fit between the front forks before I start to make fender struts and mounts. I need to order some tank and seat Bungs too. The tires will be replaced after i clean up the wheels with some Kenda Challenger tires that i picked up.
Well there it is for now, time for some sleep
